powderman426
Jan 04, 2014Explorer
AlbertaNewbie wrote:newman fulltimer wrote:
Looks like the tank froze and pushed liquid out
What he said, only thing you can do now is pull the drain plug and open the relief valve and hope you are not buying a new tank in the spring.
And if you only have one by pass valve, it means you have check valves which are prone to failure and are a PITA. I would replace the check valves with single throw shut off valves and never again worry about the heater tank. I replaced mine and it was one of the best mods I ever did.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
