Terryallan
Jan 04, 2014Explorer II
ljedik wrote:
The antifreeze is well mixed with water. Otherwise, There would be no hanging icicle. I don't know how water, and antifreeze was mixed in the tank. But it is. .
IF you didn't drain the water heater, and let the antifreeze run thru it. 2 gallons is not near enough. You have 6 gallons of water mixed with 2 gallons of antifreeze. Antifreeze that should NEVER be mixed. You would have had to use at least 8 to flush the water out of the WH, and lines. Did you let the hot water run until solid pink came out of the tap? That is the only way to know you got all the water out.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
