Airstreamer67
Jan 05, 2014Explorer
I ruined a water heater one year, even though it was "drained."
What happened: I pulled the drain plug, saw water running out and then left to do something else. When I came back, the water no longer was draining so I put the plug back in. I used no antifreeze in the rest of the system. In the spring I found the water heater was cracked.
I had made at least two mistakes: I did not open the hot water faucets in the trailer when I was "draining" the water heater, nor did I open the pressure relief valve on top of the water heater. So, apparently a vacuum was created in the hot water system that prevented full draining of the water heater.
Nowadays, when I drain the water heater I open the water faucets and the pressure relief valve and even leave the drain plug out for the winter. I also now have a bypass to the water heater and use antifreeze in the water pipe system.
Belts, suspenders, underwear...I'm covered one way or the other now.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
