MetalGator's avatar
Apr 25, 2016
Hotwater heater on Propane
I had an issue with my hot water heater not working on electric. I had a mobile mechanic come out and he replaced the thermostat and now the electric works fine. This was about a year ago.
I was camping this past weekend and I thought I would run the hot water heater on propane. I flipped the switch and the light didn't come on. I went outside and dropped the panel and one of the "reset" buttons was popped out. I pushed it back in and turned on the switch. The light didn't come on and the heater never ignited. I went back outside to check and both reset buttons were normal. Turned the heater back on electric and it works fine. The propane to the RV was turned on.
I checked the fuse and breaker panel inside the RV and everything was fine. I'm not sure what else to look at. Anyone have any ideas?
Burch
  • Water heater brand?
    Get your volt meter out. Could be any number of things, but without a volt meter your SOL!
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 14, 2025
