wa8yxm
Sep 02, 2019Explorer III
I like the solar charger idea. say a 100 watt panel should handle most if not all. monitor the voltage (battery) and if you see it start to drop go to 200 watts of panel but I think 100 will do it. DO not forget a good charge controller for a 100 watt panel you need a 10 amp controller minimum. I'd not go bigger than 20 amp for the controller or the loss in the box will be too great. MPPT is best.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
