opnspaces
Sep 02, 2019Navigator III
Yes solar or even cheaper with a second disconnect switch at the batteries.
If you go for the second disconnect make sure you wire it so that the emergency breakaway if equipped still has power. So you wiring path should be (Positive terminal --> emergency breakaway --> cutoff switch --> trailer)
The emergency breakaway doesn't pull any power unless the pin is pulled. You want the breakaway to function even if you forget to connect the batteries before towing.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
