harley-dave's avatar
harley-dave
how do I repair a stripped out screw hole in the wall
Well, the subject says it all. My Winnie has those thin wood walls and some of the screws holding misc. plates and brackets are stripping out. How do I repair the holes so I can tighten the wood screws and keep thing from coming off the wall? :(
Dave
  • donn0128 wrote:
    Down and dirty simple fix? Take a tooth pick and some Elmer's glue. Apply a small amount of glue to the tooth pick and shove it in the hole. Once the glue is dry, replace the screw. Good for nearly ever. BTW this is a great fix for particle board holes too.
    been using this trick for a while now and donn's right...the repaired hole will hold for a long, long time. but, depending on the size of the hole, you may need more than one toothpick.
  • thanks donn0128, I like simple fixes. Simple and durable is even better. I had thought about glue but needed an idea on something to put in the hole to make it smaller.
  • Down and dirty simple fix? Take a tooth pick and some Elmer's glue. Apply a small amount of glue to the tooth pick and shove it in the hole. Once the glue is dry, replace the screw. Good for nearly ever. BTW this is a great fix for particle board holes too.
