- rk911Explorer
donn0128 wrote:
Down and dirty simple fix? Take a tooth pick and some Elmer's glue. Apply a small amount of glue to the tooth pick and shove it in the hole. Once the glue is dry, replace the screw. Good for nearly ever. BTW this is a great fix for particle board holes too.
been using this trick for a while now and donn's right...the repaired hole will hold for a long, long time. but, depending on the size of the hole, you may need more than one toothpick. - harley-daveExplorerthanks donn0128, I like simple fixes. Simple and durable is even better. I had thought about glue but needed an idea on something to put in the hole to make it smaller.
- donn0128Explorer IIDown and dirty simple fix? Take a tooth pick and some Elmer's glue. Apply a small amount of glue to the tooth pick and shove it in the hole. Once the glue is dry, replace the screw. Good for nearly ever. BTW this is a great fix for particle board holes too.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
