- tvman44ExplorerI purchased the hard wired EMS unit from Progressive for 3 reasons.
1. Keep me from forgetting it at the pedestal
2. Keep it from growing legs.
3. Keep it out of the weather. - tpiExplorerSame here, have just hung it on the post with no protection. According to MFG, it is supposedly weatherproof, but not to be immersed in water. It has been through some extended downpours. For me the biggest risk is the senility quotient-forgetting it at a campsite.
- fj12ryderExplorer IIII don't do anything special, just plug it in. Usually it hangs from the post, a few times it lies on the ground. If it fails due to water I won't buy another of the same brand.
- EV2ExplorerI use my extension cord at the ped and connect the suppressor inside of the compartment. It re mains clean, dry, and secure behind the locked door.
- cbshoestringExplorer II
cbshoestring wrote:
I installed a hardwired unit. Stays dry, unless the closet leaks :B
The ammo box seems to be a good solution for cord connections, but my favorite I read on here is the portable unit installed as a permanent unit.
Cut the cord INSIDE the trailer. Place a male plug on the supply side, place a female plug on the "trailer" side. This is backwards. Male on "trailer" side, plugged into female on surge protector, which then takes male plug into newly installed female plug on supply cord.Once plugged in...your surge protector is essential permanent in a dry space.
I am not sure how it can be monitored, but it will still protect.
Edited myself...didn't mean to double post. Think I will leave it, so the mistake is easily seen. - cbshoestringExplorer III installed a hardwired unit. Stays dry, unless the closet leaks :B
Cut the cord INSIDE the trailer. Place a male plug on the supply side, place a female plug on the "trailer" side. Once plugged in...your surge protector is essential permanent in a dry space.
I am not sure how it can be monitored, but it will still protect. - PawPaw_n_GramExplorerWeather resistant doesn't mean waterproof. If the pedestal isn't high enough to keep ours off the ground, I use a short extension, and cheap folding chair. I drape it so both cords are handing down.
I do this even if there is not a forecast for rain. I never leave it lying on the ground. Been caught by surprise thunderstorms too many times. - NanciLExplorer IIMine is a Progressive.
It has been in gully washing rain storms and I have never had a problem with it.
We are snow birds and it is exposed to off and on rain storms for five months a year
Jack L - Hardwired in the RV.
- MrWizardModeratorcut your cord, put new male and female ends
get a plastic AMMO BOX
make your self a weather proof box you can lock, for your surge protector
several members have made this box for shore cord extensions to keep cord ends out of water
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
