ktmrfs
Nov 06, 2013Explorer III
oweninthekeys wrote:
And don't be fooled into believing that a weight distribution hitch will increase your allowable cgo or tonque weight. It will not!
partially true:
Usually there are two tongue weight limits on reciever hitches.
1) deadweight limit (NO WD)
2) WD tongue weight limit.
(2) is usually bigger than (1). In my case (1) is 1200lbs and (2) is 1700lbs.
So, yes a WD hitch increased my allowable tongue weight, assuming I still stay below GVWR and axle limits.
And a WD hitch will move some TV rear axle weight to the trailer axle so going across a scale it will reduce the truck GVW compared to no WD hitch. But that transfer of weight is usually fairly small, on the order of 200-300lbs. Course that weight moved went somewhere, and it ends up on the trailer axles so your combined GVW doesn't change.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
