Chris_Bryant
Sep 23, 2015Explorer II
06Fargo wrote:Dutch_12078 wrote:egarant wrote:
In regards to installing an accumulator tank, I called Shurflo and a tech told me that the pump model 4008 did not require an accumulator tank and that it would be a waste of money.
The tech was wrong... If your 4008 was pulsating, an accumulator tank would stop it. The Revolution (4008) bypass pump is supposed to eliminate cycling/surging, but it doesn't always work as well as they claim, especially at low flow rates.
Roger this ^
x3- there is an adjustment for the bypass pressure- it is not always well adjusted. Proper adjustment, or simply adding an acumulator would be a fix. The tech really dropped the ball on this- that pump should not pulsate.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
