Ron_Gratz
Aug 15, 2013Explorer
tluxon wrote:The normal procedure for adjusting a WDH is:
---Whatever weight you have in the truck behind the rear axle IS going to add to the weight that a WD hitch has to redistribute,---
1) measure the load on the front axle (or height of the front end) with the TV loaded for camping and unhitched from the TT,
2) attach the TT to the TV, and
3) adjust the WDH to return some of all of the load removed from the front axle (or eliminate some or all of the front end rise) due to addition of tongue weight.
If this procedure is used, the WDH does not have to redistribute the load which is removed from the TV's front axle due to adding weight behind the rear axle.
Ron
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 07, 2026
