kmbelt
Sep 26, 2014Explorer
95jersey wrote:lanerd wrote:95jersey wrote:
No teenagers, just my wife and 10 year old son. Dirt bike is for me only. Payload on the Ram is a bit low because of the coil springs (1280lbs). Dirt bike only weights 215lbs, so that gives me 1000lbs of remaining payload and a class IV hitch. I am sure I am within my limits, and I can put the luggage in the trailer. No steep mountain grades like out west, just rolling hills of the NE & SE.
So I think I am fine on the weight, but I have heard stories of pulling 30'+ trailers that it can be a handful with wind and lighter trucks. Just don't want to spend $10-20k and find it to be a very un-pleasurable experience.
No, you are not fine with weights. Remember a 6000 lb trailer will have anywhere from 600 to 900 lbs of tongue weight. There goes your 1000 lbs without you, wife, and son ever get into the truck.
You are not taking into consideration the actual weights that a trailer can have. Dry weight advertisements can be notoriously under what the actual weight will be once the trailer is loaded.
You need to rethink this and think about "actual" weights before actual purchase.
As far as lengths go, yes longer trailers can be more to handle especially during windy conditions as they become a huge sail. I, for one, would not consider pulling anything longer than 25' with a half ton....but that's just me. I pulled our 25' trailer for six years and even that was taxing on me and my truck....of which I had to replace the rear gears (differential) when I sold the trailer.
good luck
Ron
According to the Dodge website I am within my weights and I am considering the total weight of the trailer loaded. They have a calculator...with 3 passengers already accounted for, my towing and payload ability is the following.
Payload
1,117 lbs
Towing
8,933 lbs
Let's say the loaded weight is another 1500lbs above the dry weight. I would not tow with any liquids. For example I am looking at a 32' that weights 5650 dry + 1500 loaded = 7150lbs. This gives me a tongue weight between 715-1144 and a 20% cushion from my max tow capacity. Also GCVW is 15650, so with a curb weight of 5400lbs, I am within my limits there as well.
The dirt bike will have to be thought through, but adjusting the tongue weight using a weight distribution hitch, I am sure I can push some of the tongue weight back on the trailer to compensate the 215lb dirt bike in the bed. Throw in some air bags if needed and I should be good to go.
Again, just worried about the 32' length being too much for the 140.7" wheelbase.
Don't go by what the website tells you. It won't be accurate. Do your math based on your door sticker.
Also, have you considered a TT toy hauler? This would help with truck weight and gives room for your kid to have a bike too someday.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 16, 2026
