Lantley
Sep 26, 2014Nomad
95jersey wrote:Terryallan wrote:95jersey wrote:
I use to do 70-80mph over hundreds of miles for years without even a hint of an issue.
That right there makes you a VERY LUCKY man. If it was a travel trailer you were towing. the tires were only rated for 65 mph.
BTW. I didn't say you couldn't tow your new TT. I only said ALL the tongue weight stays on the ball in one way or another. Yes little weight is transferred thru the hitch to the TT, and a little is transferred thru the hitch to the front axle. But it ALL still on the hitch. You will be overloaded.
It was a car hauler, not a travel trailer.
Was the frontal area as large as the travel trailer you are planning to tow?
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 16, 2026
