bdpreece
Mar 31, 2015Explorer II
If the moisture is trapped inside the walls it could take a long time to dissipate and cause a lot of damage. If it were my rig and an inspection of the wall did not show any soft spots I would try to find an inconspicuous area at the top and bottom of the wall and cut holes where you could circulate air using a fan and possibly some duct work. After the moisture meter showed it was dry I would either buy or rent an ozone generator and circulate ozone through the same holes to kill mold and mildew.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
