mrekim's avatar
mrekim
How often do you need to tighen your hitch ball?
I have a ball on order and was going to get a 1 7/8" socket. After a brief search it seems like 1/2" drive tools won't cut it. I suspect that, if I want to be able to tighten this myself I'll need at least a 3/4" socket and breaker bar. This is a slightly larger investment than I anticipated, so I figured I'd ask to see what more experienced people are doing...
How many of you carry the tools necessary to tighten your 1 7/8" hitch ball?
How often do you check it?
How often should it be checked?
If you have tools, how long is the breaker bar and are you using a 6 or 12 point socket and would you use the same tools if you were buying from scratch?
I believe I can use a known weight on the end of a breaker bar or even a Sherline scale and floor jack to get the proper torque. Does this sound reasonable?
Thanks,
Mike
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
