DallasSteve
Jan 10, 2020Nomad II
Rich
Thanks for the reply, but I'm still confused. Is the GVWR (16,000) the empty weight and GCWR (23,000) the maximum load including the toad? So if I weigh the motorhome and it's at 17,000 then I have 6,000 load left (23,000 - 17,000), right? But since the hitch max is 5,000 I still can only tow 5,000 (if I have a tow bar rated at least 5,000), right? So if the Jeep loaded is under 5,000 I'm OK? But if the motorme loaded was 18,500 my max load remaining is only 4,500 (23,000 - 18,500) and that would be the limit that I could pull as a toad, right?
But then my confusion is how does the front and rear GAWR figure into this? In this case they total 17,500 (6,500 + 11,000). Can somebody please explain?
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
