ajriding
May 18, 2020Explorer II
I modified my plumbing so I have a valve on the water tank side and to an open "hose" so I can switch over to a portable 5 gallon water jug for the house water. The pump pulls it in. The jug has a tube that pulls off the bottom of the jug and the hose has a garden hose fitting so just screws in to the jug. I put the valve near the end so no water leaks out of the hose when disconnected. I carry two of these jugs if needed. They can be carried easily by hand and do not make store owners mad if you fill them as maybe filling an RV would.
I try to use the jug water first, so I have empty jugs to refill asap. Then resort to the on-board water tank last.
This is when I am boondocking seriously.
For me, washing dishes (two meals a day) seems to use the most water. I try to make the water go a long way, using the rinse water from one as the soak water for the next, and rinsing as many things at once as I can etc...
I am usually out on the trail for hours on end getting very dirty and sweaty, so the wipes are just not going to remove that. I have to shower every day, but I think I barely use more than 1 and a half gallons for that. Cold water, as waiting for hot water to get to the head is waste also. Cold showers use less water too. I have been known to put dirty dishes and other things lined up for a wash under me when showering so that water starts the process. Thoug, I do dishes like this only wen I can solo.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
