JAC1982
May 18, 2020Explorer
I'm still wondering how you managed to fill up both a black and gray tank in one day. Are your tanks teeny tiny?
We boondock often. As a female, with hair that needs to be washed every day or two, I Navy shower. Turn water on to get everything wet, turn off water. Then soap up hair, turn water on to rinse hair. Turn off water, put in hair conditioner, and then do body wash. Rinse. Done. Uses very little water, and I never run out of hot water either. A man could do it with even less.
For dishes... well, we use paper plates/utensils for the most part. Not the most eco-friendly, but saves a lot of dish water. Get one of those sponges with a handle that holds soap, so you can wash things little by little instead of a whole sink of dishes.
The toilet is the one thing we don't mess around with. Husband has Crohn's disease. We use it as normal. Easy enough to add more water with a jug to that to flush if things got really dire, but we have yet to be in that position.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
