Veebyes
May 28, 2020Explorer II
The frugal owner can run a 50amp RV on a 20amp power source.
No A/C. Leave water heater on propane & only turn it on 15 minutes or so before hot water is needed then turn it off. Leave fridge on propane. Avoid using more than one small AC heater.
I have used the A/C on 20amp however the circuit breakers for everything else, including battery charger, were turned OFF.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
