darleyhavidson
Jul 28, 2020Explorer
rk911 wrote:
first thought is you may not have that system installed correctly.
second, their ad promises 3-4 gpm flow at 60-psi. do you know what the pressure is there?
what's the flow like without the filters?
my advice...dump that filter system in favor of something simpler.
It is installed correctly. Checked it 3 different times. I don't know the gpm flow rate from the well water pump. But it is a full stream with 65 psi behind it.
I had the simpler filter system, but it did not take care of the iron and consequential sulfur smell that the well water was contributing to.
The RVwaterfilterstore.com customer service recommended I use a 5 micron carbon filter versus the .5 micron filter. The specs on both show 3-4 gpm, so not sure what will change.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 20, 2026
