down_home
Jul 28, 2020Explorer II
Did you flush the fines from each filter before connecting the next one in the series?
I have not run three but have run two in series. Perhaps and only perhaps this is contributing to partial blockage or restriction. On thing I have doe in fill the tank when pressure is low then use from the tank. Our last water pump would kick in when it was on and water pressure from the outside source was low and bring pressure up. This new identical pump not quite the same even though rated at 55 psi. Does your coach have its own pressure requlator somewhere set to 45psi?
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 20, 2026
