darleyhavidson
Jul 28, 2020Explorer
down home wrote:
Did you flush the fines from each filter before connecting the next one in the series?
I have not run three but have run two in series. Perhaps and only perhaps this is contributing to partial blockage or restriction. On thing I have doe in fill the tank when pressure is low then use from the tank. Our last water pump would kick in when it was on and water pressure from the outside source was low and bring pressure up. This new identical pump not quite the same even though rated at 55 psi. Does your coach have its own pressure requlator somewhere set to 45psi?
Carbon filter was flushed of fines prior to install, per instructions. There is no onboard pressure regulator on my RV.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 20, 2026
