darleyhavidson
Jul 30, 2020Explorer
NJRVer wrote:
How much have you used this set up?
If the iron is that bad you could have them blocked already. Time to change them. I have high iron at my well and have a filter to catch the sediment before the water softener. This traps all the **** from blocking up the watersoftener.
That filter has to be changed frequently as it blocks up quickly.
Another thing nobody mentioned. Is the flow bad out of everything or just the faucets?
Check your aerators for sediment clogging them up.
Used the filter system for one weekend. The faucet screens are clean. The shower pressure is so low it is almost not worth using. I get water out of all faucets but it is underwhelming flow and pressure.
I will have time to troubleshoot the filter system one more time tomorrow.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 20, 2026
