darleyhavidson's avatar
Jul 28, 2020
How to increase water flow AFTER the filters?
Ok, I recently installed a RVwaterfilterstore.com filter system. The filter sequence is: a 1 micron sediment filter, a .5 micron carbon filter and the final one is a metal trap canister. The campground I permanently camp at has strong well water pressure (65 psi) and great flow. After I connected the filter system the water barely flows from the hose and all the fixtures in the camper have less than ideal water pressure.
So, I would like to keep the filtration system but need an increase in water flow after the filter system. How can this be achieved?
dh
  • Did you contact the outfit that sold you the system?
  • first thought is you may not have that system installed correctly.
    second, their ad promises 3-4 gpm flow at 60-psi. do you know what the pressure is there?
    what's the flow like without the filters?
    my advice...dump that filter system in favor of something simpler.
  • Something's wrong if you have 65psi going in and barely a dribble coming out.
    Try hitting the bypass for each canister in your setup to find the bottleneck.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Aug 30, 2022
