mcguirehg's avatar
mcguirehg
How to level floor?
We needed to replace some rot. However, floor is slightly off level due to patch. What can we use to level floor prior to laying alllure? Self leveling that won't crack?
  • Good choice using bondo. It adheres well, is fairly flexible and won't crack, not like the powdered floor levelers would in an RV.
  • Ok...so I started with Bondo. I hope it comes out good. Water damage is not fun with the 5th wheel. I need to level floor and put kitchen back together. We will need to lay Allure. Fixing damage due to the drain hose. Just trying to get things back together for our summer trip...
  • Ardex found at flooring supply. Nothing better or easier to use. Excellent adhesion!
  • If the elevation difference is small, I use an organic material that comes in a can (powder). For larger areas, I use self-leveling mixes like these.
  • I had this problem in an older 5th wheel I bought to hunt in. What I did is I used body putty (Bondo) and feathered out the imperfections and sanded smooth. It worked great and now you can't tell there was ever a repair made.
  • Self leveling floor compound from most any big box store.
  • Patch is right at slide, I'm looking for a self leveling to blend everything together...it that makes sense.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 23, 2026
