RLS7201
Dec 23, 2014Explorer II
Buster, I've use the on board levelers many times to get a tire off the ground and then slide jack stands under the RV. Check the capacity of your jacks. I suspect that they are rated to lift your RV off the ground. You MUST block the front tires when raising a rear tire off the ground. I carry a bottle jack capable of lifting a rear tire when on the road. I unload the suspension some and then finish the lift with the bottle jack.
Please be safe!
Richard
95 Bounder F53
Please be safe!
Richard
95 Bounder F53
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
