kimberlysmoore
Sep 19, 2015Explorer
Homer wrote:
Check your fluid level first. Make sure your breather is not clogged.
If that is all ok take an AMP draw on the motor.
Fluid level is fine. No clogs. The levelers work. The rv seams too short to accommodate the level.
A little bit of info on front air bags..they are busted. They need to be replaced. Could that be allowing my rig to sit lower than it was originally intended? That would explain the 1 inch to 2 inch height I need to lower the leveler when I'm parked on an angle.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
