80R100RT's avatar
80R100RT
Hydraulically actuated brake controller?
Being somewhat obsolete myself, I found a NOS hydraulically actuated brake controller at a small town auto parts store. I have had them before on older vehicles and they work quite well. I have a '97 D2500 CTD and wonder if anyone knows whether the controller can work with the brake system on my truck? Thanks in advance....
  • wanderingbob wrote:
    I believe they are not for the newer dual braking systems . Your master cylinder has two systems , one for front and one for rear . Also if you have ABS it will not work properly . I to loved dem old hydrolic system but I do not think they have made them for twenty years or so .
    My MaxBrake DOES tap into the brake line where it comes out of the master cylinder. A fitting with a short piece of brake line and a Honeywell sensor on the end with a cable that goes to the controller.
    Works great!
  • Yellermanx wrote:
    ScottG wrote:
    Your really not supposed to use those with ABS.
    Not according Max Brake.
    Get the Max Brake. It works Grrrrrreeeeaaaaattttt!!!!
    Im not familiar with the system the OP posted, but I dont think you are talking about the same thing as the OP.
    MaxBrake will work with a Hydraulic Brake Actuator such as Dexter or Carlisle as advertized. It relies on hydraulic brake pressure (pressure transducer tapped into the MBC) to produce the required 0-12VDC PWM output. The OP is referring to a brake controller that is hydraulically operated.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
