wittmeba
Jun 07, 2013Explorer
Yellermanx wrote:ScottG wrote:
Your really not supposed to use those with ABS.
Not according Max Brake.
Get the Max Brake. It works Grrrrrreeeeaaaaattttt!!!!
Im not familiar with the system the OP posted, but I dont think you are talking about the same thing as the OP.
MaxBrake will work with a Hydraulic Brake Actuator such as Dexter or Carlisle as advertized. It relies on hydraulic brake pressure (pressure transducer tapped into the MBC) to produce the required 0-12VDC PWM output. The OP is referring to a brake controller that is hydraulically operated.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
