Usmcsousa
Dec 18, 2013Explorer
Thank you both..looks like the lines are leaking at all four fittings, haven't figured out just yet if the pump is bad . I cant seem to find parts for these, only full sets of four.
Will call the manufacturer for more info.
Came off a 95 Class A.. can only assume any warranty is long voided.
I suspect electrical issues coming soon as well.
If at one time it had a starter lockout, it doesn't work anymore. Or was bypassed for whatever reason i cant wrap my head around
The opposite jack has no leaks but will not retract with the in cab controls. I need to crawl under with a screwdriver to connect the two leads on the up solenoid to get it to retract. Very shady situation lowering a 17,000 lb bus toward your face.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
