NanciL's avatar
NanciL
Explorer II
Apr 11, 2018
I have a question on towing a smaller trailer
We have a neighbor who has a 4 cylinder, 2015 Chevy Equinox and she asked me if she could tow a 2,250 pound pop up trailer.
She says her book tells her that she can tow 2,500 pounds.
I don't have a clue if she can or can't, but I told her I thought she would burn out her transmission
Can anyone say if she would be ok or if she would be making a mistake?
Jack L
  • Safe bet is always staying Under the max tow rating. We had a neighbor do just that with a mini van and they smoked their tranny. They were under their tow rating, but when you factor in some good grades and high summer heat, you can kiss it all good buy.
    Brian
  • 4x4ord wrote:
    If her manual says it can tow a 2500 lb trailer I think she is fine towing a 2500 lb trailer.
    That doesn't answer the question I asked
    Jack L
  • Don't recommend going over the weight rating but also depends where she will be towing.
    Flat lands in normal conditions, she might get away with it.
    Mountains and it is far more likely to have a failure.
  • Confirming real ratings is step one - as noted above.
    After that, in the case you suggest, a 2,250 pound trailer is going to weigh more than that with propane and basic gear. Add in food, gear, passengers, etc.. in the Equinox and you will be quickly overweight. Personally, I would not tow anything but a small utility trailer with a 4 cal engine - but to each their own.
  • okhmbldr wrote:
    The 4 cylinder Equinox and GMC Terrain are rated at 1500 lbs.
    the 6 cylinder is rated at 3500 lbs.
    From the Chevrolet website,
    Yep, 4 cylinder max tow is ONLY 1500lbs.
  • The 4 cylinder Equinox and GMC Terrain are rated at 1500 lbs.
    The question is - how much does this popup trailer really weigh loaded & ready to camp? :h
  • 4x4ord's avatar
    4x4ord
    Explorer III
