KD4UPL
Jan 05, 2017Explorer II
Black, green, and white in an orange sleeve sounds like someone used an extension cord and cut it up to wire the trailer. Those colors are not standard for a 4 pin connection.
Those 3 wires are likely the left and right signals and the running lights. Ground was likely just the frame. I would suspect the blue wire as being electric brakes, blue is the standard color for that. In order to have electric brakes you must have at least a 6 pin connector (like you removed). However, most large trailers use the 7 pin. The 7th connection usually adds back-up lights.
Assuming your trailer has brakes it likely needs them to be highway legal. I strongly suggest you wire it for a 6 or 7 pin connection and add the proper wiring and brake controller to your tow vehicle.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
