Timothy2001 wrote:
Everything on the rig works, nothing on the trailer works.  No power at all to harness 30 amp breaker/fuse is good.  Trying to track down power source now,  wiring diagram not proving to be helpful.
Filling us in on exactly what type of rig and what type of trailer you are dealing with would help us help you.  Does your trailer have brakes?  If so, does your tow vehicle have a brake controller?  Do you have a 12v tester or a multi-meter?  Do you know how to use one?
I have no idea what "30 amp breaker/fuse" you're referring to, but there won't be a single fuse that feeds all of the trailer lights; so looking for a single fuse or breaker is a waste of time.  You need to start at the trailerr plug (on the tow vehicle) and test each terminal for power, then start following those wires toward their source if they don't work.
You are going to need at least 3 or 4 (or 5 if brakes) different wires that need to be hot at particular times; 1-running lights, 2-right turn/brake, 3-left turn/brake, 4-12v hot (for charging), 5-trailer brakes.  Additionally, you could have 6-backup lights (rare for a trailer), plus of course 7-ground.
