opnspaces's avatar
opnspaces
Navigator III
Dec 30, 2019
I weighed my setup
My trailer has not changed, but the tow vehicle has changed. My 1996 Suburban 3/4 ton 4x4 is dead and I now have a 2001 Suburban 3/4 ton 4x4.
So today I went to get the trailer out of storage and setup the weight distribution (WD) for the new truck. As a bonus, since there is a landfill facility about a half mile from storage I figured I'd get some weights and see what input you all can offer. When I asked about the weights the operator asked if I needed certified weights to which I answered no. When I was done weighing and looking at the numbers I can see some discrepancies which makes me wonder if the lady wrote the numbers down wrong, or if their scale is really that off. In the end though I don't think the differences in weights are enough to worry about. At least not at this point in setting up the hitch.
Here are the numbers. The truck and trailer look level and pulled fine although there was definitely more porpoising than with the older Suburban. I'm thinking I need more front axle weight although I'm surprised how close the initial numbers seem to be. Any suggestions if it was yours or would you leave it alone?
Weights labeled "Whole truck is front and rear wheels on the scale"
Rear axle calculated is because there was no way to get rear alone with a trailer hooked up so I subtracted the front axle from the whole truck number.
Had to edit this post as I realized that it wasn't clear that the trailer weight was with the trailer still hooked to the hitch.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
