tropical36
Jun 05, 2013Explorer
wheel.estate wrote:
has anyone tried to install seperate lights to tow a jeep wrangler in the newer tail lights instead of putting in the blocking diodes?
COOLTECH is the way to go for the JK series Wrangler. Just plug it in the driver's side tail lights and install a connector on the front. Plug and play, no diodes, no nuttin.... Click it....COOLTECH
I did recently help a friend with an older Jeep in which we just ran a harness to the rear with a 4 pin connector attached and then mounted some LED lights on a hitch haul that just plugs in. He uses it like we do to haul bikes or extra cargo, so it's needed when being towed anyway. One could use a light bar of angle iron as well. He also can plug it in to his tow lights as well if he desires them to work when not being towed.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
