enblethen
Oct 08, 2013Nomad
If you purchased the one with the red handle, there is two bolt holes to mount it. Red handle portion would be on outside. Of course if you have battery box wityh limited end or side spave you could have a problem, other then mounting it to the cover. You could get a 4 inch covered electrical box and mount it to the outside of the battery box or on the frame.
The one with green knob works very well. Just mount it to the battery terminal and bolt you wires to the pin provided.
battery switches.
Remember if you plan on twoing with the battery disconnect in the open position that you must wire your brakes to the hot side of the switch.
battery switches.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
