sandstravels's avatar
sandstravels
Inverter Charger
My 12 year old Xantrex Prosine 2.0 has finally bit the dust. I used it in 2 RV's and it has served me well. I learned about the Prosine 2.0 on this forum years ago. It was a 2k watt pure sine inverter/charger. I have 4 135ah 6v batteries. What is the similar latest and greatest product today? Thanks for your help.
  • time2roll wrote:
    Good time to switch to separate components. Then you only diagnose, repair, replace or bypass the piece that failed. I use a stand alone GoPower 2000 watt sine wave inverter.
    Sounds like good advice, thank you. Now let me re-ask the question, What is the latest and greatest charger/converter and the latest and greatest inverter?
  • The only reason for an inverter/charger is if you need the hybrid type. Otherwise stand alone components are more desirable.
  • After much discussion and advice last year, I decided to go with a separate ATS (automatic transfer switch), even though my Prosine has a built-in transfer switch with the inverter.
    I like this for multiple reasons, one of which is not limiting my shore power load to the amperage of the inverter unit.
    I can easily use a smallish or largish inverter and with the 30amp ATS I have...get full 30 amps when plugged into shore power or the generator.
    I also like the ability to fully control the inverter state, though I've not had experience with using the in-built version ;)
    That being said, I'd agree with the above advice- separate components. Might even find a more frugal unit whose pricing went into "inverter components" instead of ATS components ;)
  • Good time to switch to separate components. Then you only diagnose, repair, replace or bypass the piece that failed. I use a stand alone GoPower 2000 watt sine wave inverter.
  • Check out the Samlex EVO-2212 inverter/charger/transfer switch. They may be new to RVers, but this company has been around for awhile.
    I really like their design because of the simple installation. All connections are made at the inverter/charger/transfer switch.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 08, 2025
