t500hps's avatar
t500hps
Inverter generators (power in the paddock)
I'm sure a few of you have faced the same dilemma I'm looking at right now:
I have a toyhauler with a 13.5 BTU AC on the roof that is used at the track when racing. While power is available, there are not very many poles and most people can't get power without arriving the day before.
I need roughly 2,500 watts to run the AC and a couple lights (frig/heat/HW are all propane).....and I already have a Honda EU2000.
So my options are another Honda EU2000 Companion to parallel with the one I have, or a larger inverter/generator to power it all. I've found a Champion 3100 watt unit that is getting good reviews. Cost is a factor since anything I buy won't be used a lot but I don't want junk either. The Honda 2000 is about $1,100 with a $60 cord needed, the Champion is cheaper ($830) with nothing else needed. Backup power at the house is a non-issue since I have a large unit for the house.
Is 2 lighter units easier to deal with than one heavier unit? Noise from these 2 is nearly the same. If I buy the Champion I could sell the Honda however, I realize the Honda(s) is the better unit. Yamaha's or other 3,000 watt units are also considered but I'm getting into the $2,000+ range for any of those.
Suggestions or experiences?
  • Do you ever have need for an inverter? A Victron Multiplus will add and combine power with the honda to get the air running and then recharge the battery. Temporary additional loads could be carried by the battery. This would allow the use of one honda and probably an extended run fuel tank. OK this is not exactly the easiest low cost solution but saves the cost of a second honda. Inverter can also be used alone if needed during quiet hours.
  • Hi,
    Another option is to move to a hybrid inverter. That will allow the battery bank to pick up the start up surge without stalling out the Honda, and even allowing the use of the eco switch.
  • We have a Yamaha 3000. Weight is an issue. Takes 2 to load in back of truck. We use it once a month at motorcycle races (7 months a year). Usually runs 24-30 hours each time. It runs our 15,000 btu ac fine and will usually go 10+ hours on a 3.5 gal. tank of gas.
    I don't like the weight, but I do like the long run time. Had no issues with unit.
  • 2 units are a mixed blessing, easier to move but more effort to maintain.
    Since you already have one I would lean towards a second matching unit.
    We have a single yamaha 2400 that we use. If you didn't have the honda already, I would suggest something in the 2400-3000watt range depending on your ability to lift and move the unit.
  • I have the 2 Honda solution which works fine - do make sure one is a "companion" if you want to run the A/C. I have to lift the generators out, so two is easier. With a toy hauler you would presumably roll the generator down the ramp. In that case I like the one bigger generator solution. Just my free advice which is worth what you pay.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
