nayther's avatar
nayther
Inverter Help
Gathering up the materials/devices to start installing in our new rig which we'll have in a couple of weeks. Base line will be 2 T-105 GC 6 volt and 3000I Honda with remote start. Trailer is "solar ready" meaning wired from roof to charge controller location to battery compartment (at least I think that's what they mean, it's not the stupid little plug for a portable panel wired direct to the battery) so a 3 panel solar system is down the road shortly. Now my major question is do I get a super duper all in one inverter/charger with auto transfer or a less expensive inverter with a manual switchover? I'd like to keep the inverter on 24/7 when boondocking to maintain satellite settings, etc. I think the converter is a 3 stage but probably low amps
We dry camp in the desert most of the time but usually only a few days at a time so battery capacity should be OK with the 2 GC's and running the generator morning/evening for a couple of hours
I'm looking at 3,000 watt inverter so we CAN run the coffee pot if we're in a place where we can't run the generator early.
I've read a lot of threads here regarding this, separate components and ATS, all in ones with multistage chargers, etc. and some negatives about having both inverter and shore power connected simultaneously.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
