jwmII
Dec 11, 2014Explorer
Dr Jay wrote:
Hi, I have had the Stay and Play for several years and it has works fine. There is no problem with it. The only thing I wish I had was an indicator in the MH that shows when the brakes to the "toad" are applied. The LED light indicator they provide cannot be seen well with the rear view TV monitor.
Are you sure that indicator you are hanging on the mirror is not a transmitter that sends a signal to the receiver with an indicator light in the motorhome. My present SMI unit is an older Plug and Play unit and it uses the transmitter in the toad that is wired to the brake light switch. When the toad brakes apply the transmitter signals the light in the coach and you know precisely when the brakes are applied and released. Sounds like you are missing part of your setup.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
