DallasSteve's avatar
DallasSteve
Nomad II
Jul 21, 2023
Is a roof leak covered by warranty?
I just discovered that my 2022 Jayco travel trailer which I bought in February, 2023 has a roof leak. Would a roof leak be a covered warranty item or will they say that a leaking seal (if that's what it is) is a maintenance item?
Thanks, Stephen Gaines
  • Most RV maintenance info I have read, says check your roof seals once a year. You've only had the unit for 5 months. Don't let them tell you it is a maintenance issue. If they do, tell them they should have done the maintenance before you took delivery.
    Good luck!
    -Michael
  • Start with the dealer. If they won't fix it, contact your insurance company and submit a claim. Don't rely on what others tell you is going to happen because no one knows.
  • Its a 2023.... YOU purchased it NEW 5 months ago.... take it to the dealer and have them fixit... NO REASON they should deny that..
  • They will say it's a maintenace issue to try and weasel out of paying.
    If you haven't inspected the caulking, then they'll probably deny it since that a maintenance issue.
    If the roof membrane is bad, then the it should be covered by the membrane manufacturer's warranty.
Looking for advice before your next adventure? Look no further.25,171 PostsLatest Activity: Aug 30, 2025
