- rv2goExplorer II
wa8yxm wrote:
In some areas keeping the FRESH tank full is recommended.. Change the water from time to time and use a bit of heat if needed.
WHY: Well can you count on your default water supply?
The OP stated that the RV would be in storage. - Deb_and_Ed_MExplorer II
But chances are that the fresh tank still has a skinny little drain tube that extends underneath the RV, that will freeze in the blink of an eye.... - Deb_and_Ed_MExplorer II
ScottG wrote:
Keep in mind that if you leave enough water in the tank to fill the shot section of pipe going to the drain, it will freeze and bust the pipe.
Agreed!!! The ability of ice to destroy things is amazing. And it forms rather fast with temps in the 20s.... - Dennis12ExplorerCall and get a price to repair what may or could go wrong. Then you make up your own mind from that point.
- wa8yxmExplorer IIIIn some areas keeping the FRESH tank full is recommended.. Change the water from time to time and use a bit of heat if needed.
WHY: Well can you count on your default water supply? - valhalla360NavigatorThis is a great plan...if you want to learn how to do plumbing repairs.
- Grit_dogNavigator IIICrazy? No.
Silly and/or unnecessary? Yes. - DrewEExplorer IIIThere's no need for the gasket material to be kept moist with water. If you think about it, the seals on the output side of the valve (which are the same material as on the input side) are dry practically all the time, or at least should be. The whole point of the gasket, be it rubber or silicone or whatever material they use, is to be impervious to water as it seals.
- ScottGNomadKeep in mind that if you leave enough water in the tank to fill the shot section of pipe going to the drain, it will freeze and bust the pipe.
- SidecarFlipExplorer III
rv2go wrote:
When I gamble in Vegas, I lose. :B
Why gamble on the weather, drain the tanks and winterize.
If people didn't loose, there would not be those big fancy casino's. They plan on you loosing. keeps them in business.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
