Terryallan
Oct 06, 2015Explorer II
I don't know what type of Sway control you are using. however. Sway bar manufacturers suggest you loosen, or remove it in the rain, or other slick condition. They can cause the TV to go straight in a turn.
From the Reese sway control bar instructions
4. When towing during slippery conditions such as wet, icy, or snow-covered roads or on loose gravel, turn on/off handle (5)
counterclockwise until all tension is removed from unit. Failure to do so could prevent tow vehicle and trailer from turning properly.
I wonder if that could be adding to the "wiggle" feel?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
