goducks10
Oct 07, 2015Explorer
I had almost the same exact combo as you. I have a 12 Ram 2500 CTD CC LB and used to tow a 72-7300lb loaded TT. MY tongue weight was 900-950lbs. After hitching up and without the spring bars snapped up the front of the 2500 only raised up 1/4-1/2". The Cummins up front weighs a ton and it takes a good amount of counter weight to raise the front. I hardly put much tension on the 1000lb spring bars. Towed in all kinds of conditions except snow and never had truck wiggle problem.
My suggestion is to reduce the head tilt and put less pressure on the spring bars.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
