sportsman_500's avatar
Jul 27, 2014
Is the left side of my trailer heavier?
Looking for some input. I have been trying to dial in the set-up on my new to me 2008 Ram and Raptor 3018. My hitch is a Reese Strait Line dual cam w/ 1,200 lb. trunnion bars.
My issue is it always takes a lot more grunt to snap up the left side bar vs. the right. I always hitch up the exact same way. I drop the coupler on the ball, lock the hitch and raise the truck and trailer until I really hear the jack straining. I then snap up the bars in no particular order but no matter what the order the right side I can almost snap the bracket up by hand without my cheater. The left is always wayyyyy harder. I have swapped bars, tried different bars with no difference.
My generator is on the left side up front but can it make that much difference? I really think the uneven pressure on the bars can cause some sway issues which is what I am battling.
  • If you are hooking up totally level with both truck and trailer, left to right, and perfectly straight on with each other (like that always happens!!!), weight wouldn't be any issue. If either is not level or if angled to one side, then of course, one side would need more effort.
    On my DC, I can feel that the right side generally needs a bit more effort, and that of course depends on alignment, and campsite!! BUT, I have found that one of my three heads I have acquired, isn't welded exactly vertical!! (Great work nowdays!!) Also, when you hook up one side, the head will tilt toward the unhooked side, depending on how much play is in your receiver, creating a bit more effort lifting the second side.
    Of course, as the weight police always say, you should weigh your setup and that can determine if it is that much out of balance!!!!
  • It's possible, wheel by wheel weight (most closed highway truck weigh-stations leave the scale one)
  • Did you weigh it? If you did then you will know, if you didn't no one knows.
