Dr_Quick
Jul 17, 2013Explorer II
I believe that any electrical service for a second AC would be 120 volt. If there is a wire up there, about the only things that you might be able to do are, get a small 12 volt DC transformer rated for fan size and conceal it some ware near fan. Or if you can trace down where second AC electrical line is located, you might be able to switch it over to the 12 volt side of converter. But if I did this, I would be very careful to mark both ends of the line that it was changed to 12 volts.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
