way2roll's avatar
way2roll
Trailblazer
Feb 22, 2023
Is there such a thing a decent valve extender?
In every MH we've owned the valve extenders leaked. This brand new MH is no exception. Prepping for a trip and checking PSI and sure enough one of the rear duals was only showing 20 PSI. Turns out the extender was the culprit. And not at the threads but at the crimped joint. So I removed it and will make due on this trip but I need to get new extension because I simply can't check PSI or fill the tires without them. Darned if you do and darned if you don't. So, is there such a thing as a good set of valve extenders - and on top of that, ones that work well with an aftermarket TPMS - preferably a flow through?
  • One warning on the Borg/Dually Valves. Some tire shops have tire machines that are not set up to accommodate this style valve stem.
    They either set the tire/wheel down on the stem, or force the wheel onto the tire machine.
    What happens is that bends the valve stem. Then it won't fit in the rubber stabilizer when the wheel is back on the hub.
    Every time I get new tires, it is a chore to convince them not to bend the valve stems.
  • Thanks for all the responses. I hadn't thought of the actual longer valve stems installed so I think I will go that route. It's just not worth the risk putting braided ones back on.
  • As mentioned before,The ones you need are from Borg AKA Your Tire Supply. Dually Kit Duallyvalves can work with External TPMS that go on the end of the valve stem. I have had the ones from the Tireman for over 12 years with TPMS and have not had a leak or any problems.
    DO NOT put the braided extenders on, they will leak and if they come loose from their mount on the wheel they will cause a catastrophic air loss.
  • JoeH's avatar
    JoeH
    Explorer III
    Not extentions, but actual longer valve stems that don't leak at Borg Valve Stems
    Also can get similar at most truck tire places..... you do have to dismount the wheels/tires to install.
  • I tried three different models with my truck duallies, and all of them leaked at some point. One leaked immediately, and the other two leaked eventually. Surely they've improved them in 10-15 years. :)
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
