FIRE_UP
Jul 08, 2018Explorer
All really good advice so far. But, even if it was a fuse, why would BOTH brake lights go out at the same time? About 99.99999% of the trailer connectors on 99.99999% of the motorhomes/trucks/space ships etc. have:
1. Right turn/brake
2. Left turn/brake
3. Tail/marker
4. Ground
.... And so on. I can see one side (brake light AND turn signal since they're the same signal at the trailer connector) but, both at the same exact time? I'm by far, not the sharpest tool in the shed so, I could be really blind as to what you're suggesting. I do know about the pin thing where, those pins collapse a bit and, one needs to get into them and pry them apart just a scoch so they make a better contact with the female counterparts inside the other half of the connector. I had a problem just like that in setting up a buddies Jeep for towing. Took a bit of head scratching on that one.
Anyway, it will be interesting to see what the OP finds out is the problem.
Scott
1. Right turn/brake
2. Left turn/brake
3. Tail/marker
4. Ground
Scott
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
