John_Wayne
Jul 14, 2018Explorer II
Take a test light and turn on the left turn signal with the toad cord plugged into the back of the MH test each plug hole to see if your getting power to the toad should be one of the two lower plug holes if the bar for outside of the plug is on the top. Then do the same with the Right turn signal. If they work the problem is on the toad side could be just a ground problem.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
